Would a 48mm Blackjack carb be good for freestyle as a single setup on a ported 701?
steve-uk
Manners cost nothing
Barrie - ontario
reed spacers... differnt schools of thought so say it improves bottom end others say it removes bottom end
i ran a ski with and without and noticed zero difference between them
QJS
X-
GONE
I am always cautious about using manifold spacers with single manifolds because you lose the centre bolt that holds the manifold on thus making air leaks more likely. If you do decide to use one be sure to use some 3 bond 1211 on all gaskets.
Chris.
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
Chris, I did use some sealant on all surfaces + I tightened everything like 4 times in different time periods. Should work fine. Hopefully you will tell me what curve I should use, once I start playing with the EPIC for real.
