- chicago
Hey guys once again I am back with another issue. I actually thought I was done. This issue happened once before but went away this last ride.
So it won't run if I give it any gas. It will only idle. Just an hour of riding before this and it was running fine then it started doing this after I went to restart it.
So far I've check the plugs and no issue and also discovered that there seems to be an exhaust leak at the coupler that needs to be fixed. Could this be the issue?
From reading on here maybe the filter in the carb is plugged up?
Any info/ideas would be great guys.
Thanks in advance.
Thanks in advance.
