Conquistador
B-Saw
- Virginia Beach, VA
I am finishing up a 750 swap into my 550. With the added weight of reinforcement, a 750 motor, & oversized (5.5 gal) gas tank. (I may add footholds later too). Do you think that this thing may actually float if the bay fills with water in an accident. I have my doubts & the only reason I ask is b/c it happened last year more than once for different reasons. Time #1-no hood straps, have em now. Time #2-ski was hit by another ski & put a hole in the front. Both times only about 6 inches of the back end was visible above water.
I'm considering putting some expanding foam in the small area in infront of the handlepole/waterbox. Maybe it will float with the xtra area of air in a 1/2 full tank.:hail:
Any suggestions on ways to make this thing float better will be appreciated.
& I am not replacing it with a sj hull/701 yamalog motor etc. :cool2:
