- Cornelius, NC
How does this material look for a wide tray and some miscellaneous backing on a 2016 SJ? Not worried about having a little extra I'll be doing three trays but not all at once.
I have a 5 year old who sometimes rides bouys with me so the extra room for him plus occasionally carrying bouys and weights is making a wide tray seem like a worthy endeavor.
I've watched the RSKI video numerous times and I'm ready to start cutting these footholds out, just want to have ducks in a row. I know I'll need other supplies like mixing cups, gloves brushes and the like. I am good on tools, have an extensive background in finish carpentry. My service body is equipped with necessary tools and blades. I work with my hands and these tools every day, except I don't have a tremendous amount of experience with fiberglass and resin.. I use maybe a quart of body filler per year repairing and painting windows and doors damaged in shipping to keep secrets. I can do bodywork pretty ok but tbh I would rather be making a tray out of wood than learning glass and resin.
I'll be adding another tube through the tray that may not be used right away but because I can. I will probably add drain bungs, seal whatever I can from any side I can.
I do not have pour foam on the list, brings me to another question. Seems like any foam will absorb water if given the chance... I have enough gun foam from OSI to raise the titanic. I work with it on the daily and am familiar with the characteristics of how it cures. It dries hard as a rock and can be cut, sanded and shaped seemingly as well as the two part variety I've seen on YouTube. Looks like all of it has to be sealed prior to laying glass. This bare cured foam can be dented with a hammer, but if there's an inch of this cured foam between two pieces of wood, you're not going to crush it. It is light years ahead of great stuff gun foam, I have been through hundreds of cans of great stuff, maybe a thousand cans of OSI. It is consistent from the start of the can to the last and doesn't develop spots that over inflate and cure brittle. I'd like to use what I have for free, but I am all ears if even higher quality gun foam is just a terrible idea for filling a tray and shaping gunwales.
Curious if anyone has any thoughts on this kit instead of learning how to hand lay glass on my own ski.
What I don't like is how sharp the inner edge of the gunwales appear to be. That's an area I'd like to have additional padding inside that area for sides of shins and maybe some on top for elbows Looks like it would be hard to turf. If anyone has had a good or bad experience lmk.
Has anyone regretted a wide tray for a bouy/rec ski? Any designs you would have done differently?
Thanks,
Patrick
Thanks,
Patrick
