I'm not talking about that monster rotary x2.6 on youtube, this could be what saves stand-ups this time around.
AIXRO XR50 Specifications
4-stroke single rotor rotary engine
44 hp at 8750 rpm
37.5 lbs
28 ft-lbs at 7500 rpm
294 ccm
10800 max rpm
magnet ignition with variable ignition timing
Change that to a 2-rotor engine at 88 hp, weight would be roughly 5/3 of a single rotor engine ~ 62 lbs + no heavy GIANT expansion chamber exhaust, can probably use common jet ski carbs, common 2-stroke fuel, common starter, comparable fuel efficiency (or lack thereof), can be turbo'd and there are karting guys getting 50hp out of a N/A single rotor engine.... minor problems would be engineering a 2-rotor monster to work with our common parts and mounting it to the hull (enough clearance?). similar water ingestion issues but there is no crankcase to drain, and COST, I imagine these wankles are expensive.
http://www.woelfle-engineering.com/
44 hp at 8750 rpm
37.5 lbs
294 ccm
10800 max rpm
