Silicone and fuel/oil don't play well together and it will swell up to 4 times it's cured size, soften, break down and let loose. 5200 will react as well but it takes a lot more exposure.
IMO, this is why results and opinions vary so much on this subject. If you keep your bilge nice and clean with no leaks then you may have good results for an extended period but even a short exposure to fuel can alter those results. I learned this this the hard way on my 07 SJ with the bilge pumps 5200'd down. My tank pressurized and forced fuel out of a loose line and put about an inch of fuel in my hull. All the 5200 under the hood swelled up and fell apart. I rivet all my pumps down ever since.
I did a ton of product research when I first started making grommets for my bilge kits and the hardest test to pass was the fuel/oil soak test. I took cured samples of different silicone products, placed half the sample in a 32:1 mixure of fuel/oil and measured swell after 48 hrs. Some were as high as 450% swell in 24hrs. Almost all returned to near original size when the exposure was removed but the damage to bonding was already done.
