- amarillo ,tx
wow hit the nail on the head that time. :haha:
Now can someone bill me in on the big differences between the square nose and round nose superjets? I know the years they were produced and that one has a 650 vs 701cc motor. Where lower hulls the same? carbs? pumps etc? I see what seems to be alot of swapping between these two usually taking from a round nose and putting into a square nose.
What is the reason they're better in surf and freestyle? the hull? horsepower?
They probably wouldn't if they were 144mm, I was surprised to see Malone runs a kawi style mag, they like the bulkhead bearing setup a lot better.Its the pump more than anyting. How many Kawasaki owners replace the entire pump/inlet with a Yamaha unit?
I personally purchased a RN. I could ahve had a SN for much cheaper, but my motivating factor was the age. My RN is a 2004 that was rarely riden, is pretty clean and is all stock. All SN are 1995 or older, are less likely to be in as good of condition, are more likely to have had more owners, and are more likely to have more modifications. Modifications may be something you want since you can get a bigger bang for your buck buying them already on a ski, but I wanted stock because it is reliable. I already have a very modified X2 that pulls hard away from a stock SJ. I bought my SJ to know I had a ski that would rarely need a wrench.
