ATS_Aaron
X-
- Shady Shores, TX
If you loosen your low speed screw too much it will actually draw air into the fuel system and cause the exact lean condition you are trying to fix.
Aaron
Aaron
Aaron
The "problem" is that once it hits the water it is so much fun I don't want to stop to work on it.
If you loosen your low speed screw too much...
Well it was really dumb. I wasn't keeping track, just going 1/2 turn here, half turn there...ended up over 4 turns out. Oops.How much are you opening it?
Oh yeah, I think I have been going the wrong way with my power valve adjustment. I've been going tighter and tighter. Kyle sent me the stiffer springs (from memory) last summer. My ski RIPS on longer pulls, like a 2 second straight line blast, but doesn't have the same punch off a setup wake. I am thinking that the quick brap just doesn't have enough time to build enough back pressure to pop the power valves open.
Aaron
