Ericfox
Do it twice?That's DooDoo
- Akron area --> OHIO!
I turfed the nose of my ski - mainly to cover fiberglass repair work i had to do from smashing into the bottom too many times.
no padding on the rails...
when i turf the tray area sides i cut my turf using a template, then leave the area where the footholds are extra long then use a heat gun to heat up the turf and basically "push" it in to allow the turf to mold to the inside of the foothold. No cuts. Start by the bulkead and work the turf back until you reach the foothold area, then use the heat gun to heat up the turf. It takes some practice though... the turf will split if you try to stretch it too much.
However, this last time i turfed i extended my holds out to add more "overhang" for my foot... so i had to cut my turf a little and scab in a piece.
I used 25mm under pad on my tray, including into the footholds however, before i glued the padding in i sanded the foothold area of the pad so that it tappered down from 25mm to about 12mm. I made it to fit fairly snug.
You can also pad the top side of the foothold to make an even tighter fit. it all comes down to preference and comfort.
Ok. I will cut up some pieces of padding and turf and kinda get up on my ski and try to mock it up to see how my foot will fit in with the thickness of the pad/turf....
I really hope this comes out good... if it doesnt then at least it will function good and look OK... I will be taking my time!!!!!
