who runs a single 48 on t cases?
butti
lone wolf
F-XTC
if you run a single 48 on t cases please post your setup and jetting
the reason i ask is because im in the process of tuning my new setup
its a pump gas ported 701 on t cases 155lbs comp,rad charging wheel,and bnr 48.jetting is 2.5 n+s 140 main 112 pilot 28lbs popoff
i spoke to two well respected builders who both do 48 mods and got drasticly different jetting recomondations.right now im about in the middle and making progress but i thought i would get a little feedback from some folks that already run this setup
Takeastand SJ
R.I.P. 8/9/2008
Washington
I run a single 48 powerbomb, I can't remember exactly what my settings are but something around 150H 2.5N/S 80 return line restrictor. Can't remember the low I'll look for my sheet I wrote them down on.
