- outer banks
what size motor are u installing from jetworks he ported my 701 this winter think i want to upgrade!
I'm running the same 5mil stroked 900, no changes other than the pipe.what size motor are u installing from jetworks he ported my 701 this winter think i want to upgrade!
I pulled the retaining screws out and siliconed the holes, I might be able to get them out again with the pump in there to loctite.A little tip, Lock tight those screws on the scupper and also re-glue the whole scuppa in your self.
Have you seen any other issues with these boats? I'm tempted to move over from a FR2 Evo.Nice, the reaper is so similar to what your build is. But the scupper. that little thing can stuff your whole boat. I have seen about 4 that we pulled out and installed again, we were glad we did.
Will do. I have a feeling flush with a little D cut will be where it ends up at.Do yourself a favor and cut the ride plate flush with the back of the hull
No trimming with the ninja pad. I'll get pics up shortly.i saw that systeme last week on his site i like it show me how it fitts with rrp pad will u need to trim it for the hight?
I thought the same thing about the pointy edges when I first saw it but it's grown on me I guess. Once the bars are bolted on (directly over the mounting ears) they aren't exposed. Padding will go on for sure, heard that same thing from a few different people.my buddy just put one on his rrp and he said he likes it. faster more responsive steering. my only complaint when looking at it was where the steering cable cable attaches is machined into the part as a whole instead of bolting on seprate, and its shaped like a dagger. you do need to pad the underside of your pole when running ovp style steering because you will bash your knee, i guarantee.
This boat is going together way easier than some of the other builds I've done. Most of the little tweaks have been my own ocd on stuff. This thing is flying together considering I've only put about a week into it an hour at a time each night.No, the build is awesome. I think if you ask around a bit, you find out the 2 or 3 things that make it easier. and then also the issues like zie scupper. We took extra precaution on anything known. I have ridden the predator and find it so easy, considering im a blaster guy, that may not say much.. but it slashed like i wished the b1 would. The reaper to the rescue..
I think the 1st AM build is tricky and frustrating, but now we know, its far easier
