I always thought I was testing the compression on my engine properly until one day I decided to play with the fittings provided... I used to just attach the hose to my engine and crank away with the throttle pinned. That would give me 195psi. Then I added the long reach fitting because it fit and looks similar to the spark plugs. I thought that adding the fitting would increase the pressure slightly but no. With the long reach fitting attached, the numbers measured 175psi.
That's a pretty big difference...Which way is correct?
