- South Florida
If you were building a hull from scratch, what would you use?
I'm about to build a stunt hull and want a drain that drains fast and doesn't leak when I'm floating in the lake talking.
Is the Blowsion one way valve a ball valve or a regular one way valve with a flapper like the Zoeller or Home Depot valve? It seems like the best option for the money if it is a ball valve.
The versaplug looks good but it sticks out a lot and doesn't look like it would drain very fast.
The Thrust Innovations valve looks cool but sticks out a little bit and is kind of pricey.
Scuppers are known for leaking but are easily replaced without tearing into the hull. All the other options would be harder to replace if they start to leak.
