Which head is better?, Riva, R&N, Protec??
Darkside
Ax Man
Which head is better? Which is the best Riva, R&D, ADA, Protec? Superjet gurus give me your knowledge? I have a 2000 superjet with a Factory b-pipe and flame arrestors, that is it for motor mods. I want to run pump gas.
demolition_x
Not After Fame & Fortune
most people run ada. they have less orings then the rivas.
but some say the riva has the proper cooling configuration for maximum cooling.
go with either or. i went riva cause i got a good deal.
compression is compression. just get a girdled head
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Don't waste you hard earned $$! Just get the ADA! I never have failures with them and the cooling is a preference that doesn't weigh much. The one thing is the domes will never crack and is very stroker friendly for later on...just machine a new custom set, or use kaw flattop domes in the yamaha head shell...so with this in mind hands down on the choice! ADA
THRUST
ThrustInnovations.com
go with the ada if you get the riva and you ever tkae it apart you have ten pain in the but orings to get to stay where they are supposed to be . but if you can get the girdle bolt kit riva and the ada head . because the riva kit allows you to bolt the cylinder down and then the head so the cylinder stays still if you remove the head to inspect or change orings . which keeps your base gasket sealed . where the ada does not but for sure go with ada regardless.
michael950
for me to POOP on!
Houston, TX
Yeah, Riva and Protec cost more money...
ADA Complete: $345
Protec:
C2 head shell - 701/760 $390
C2 Full girdle update kit - 701/760* $240
Riva:
Head Cap, Non-Girdled, 2cyl, 3 Exhaust Mounts $130
Girdled Head Body Kit, 2 Cyl. (81-85.5MM Bore) $240
Domes $39.95 ea
TOTAL: $370 + $80.00 domes = $450.00
meatball
User Title Unavailable
Maryland
good point.
Wax had a good piece of info on how the cooling is routed for both heads, and that ADA is a 1 piece whereas RIVA is a 2 piece. They both essentially will give you the same performance, but it is by my understanding that the Riva gives you better cooling, less chance of hot spots on your cylinder.
cookerq62
Life's Been Good
Upper Bucks, PA
I have that protec head. I think the domes are a little diff then the ada heads. Also having to put silicon on the head when you take it off is a pita. I have it because it was $40 on ebay.
waxhead
wannabe backflipper
gold coast
i prefer the riva i have never had an issue with leaking of orings or broken domes
i think both the riva and the ada are a good thing
i prefer the cooling on the riva
i also prefer the way the water comes out the very end i think it looks better than coming out the top
hangtime
Speak up ,don't kiss azz
I have an ADA and love it for it's performance and looks .I try not to buy anything from Riva if I can help it because of their lousy customer service .
ADA customer service is great ,they sent me two -90 degree fittings priority mail when I requested those instead of straight fittings .:biggthumpup:
