Wheres your bildge outlet
IceRocket1286
Metro Detroit
your best bet is out the right side, the pipe is on the other and its HOT
this is a bad pic but you can see both of mine
orange flattop freestyler
The Carlsberg ski
Essex UK
Mine is on the left side, but i like em in the dash as it looks neater IMO,
When my ski gets rebuilt i'll put em in the dash :biggrin:
kingnothing3
give me fuel give me fire
h2odesperado said:
mine is in the same spot as that too... cept I put my bilge between the tank and motor, and I still use the stock bilge.
the problem with putting the bilge between the tank and motor is that it only works when your flat and moving slow or when there is alot of water. Your better off putting it in the back behind the motor because thats where the water goes when your riding due to you standing on the back and momentum
Waste Land
Non Multa Sed Multum
Florence, AL
mine are right of my carbs
Useless spot...move it back to rear and scrap the stock....
hangtime
Speak up ,don't kiss azz
I have mine on the left side too but would consider putting them in the dash ONLY because it is above the water line .I'm not worried about oil and gas .If you have enough oil and gas to be worried about it coming out your bilges than you have more to worry about than a slippery tray .:headbang: A 45 degree in the dash sends most of it overboard anyway
45 degree outlets in the tray is the cleanest install. if youre eliminating the choke and on/res valve, there are your two holes to mount them as well.
Keith
Landlocked
Nebraska
Thats a good idea and you dont have to put any more holes in the hull. My only problem is my primer and tach are in those spots. I can relocate my primer inside the engine compartment but I want to keep my tach where it is for now.
hangtime
Wow you have a tach ,I've never seen anyone with a tach on their boat.
do you really need a tach or a bilge outlet :Banane01:
unless you have the crappy stock plastic on your dash, you should have enough room for all of the above
Proformance1
Liquid Insanity
Vendor Account
New York Crew
On the opposite side of the exhaust. I have the switch on the on/off switch. Bilge is also automatic, it checks for H2O every 20-30 sec.
hangtime
Those handlebar mounted switches are junk and expensive (I've paid for 3 of em and everyone failed me )and the automatic bilges suck too .one tiny gulp of air and they shut off for 30 seconds and what if you need it to pump in that 30 seconds .:headbang:
Manual attwoods are the best and rotary switches are the best .
I have rules but peeps say the attwooods don't get airbound like the rules do and the rotary switches are the shiznit man :arms:
