Super Jet Where to start out with tuning 61x
I have a 61x motor with a sbn 44 on it. OEM exhaust and a Tau Ceti F/A on it. The jets are 145m, 120p, 95 gram spring, and 2.3 N/S. Where do I start with high and low speed adjustment screws. I just rejetted it, and started with both screws out ahout a half turn. There's so much fuel pouring into the carbs that I have to remove the pulse line or it will flood out and not start. Where do I go from here?
sharkcus
Breakin' the atmosphere.
Strongsville, OH
Why did you rejet and why did you go with those jets? I would think with a stock exhaust on a stock motor you would want to run.....stock.
You said "There's so much fuel pouring into the carbs"
Do you have dual 44s? Or a single?
It is a single 44 sbn with a F/A on it. It had a factory b-pipe on it that I pulled off and put the oem exhaust on it. Am I off on my jetting numbers with the F/A?
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Do you still have the stock flame arrestor? No point in running an aftermarket one on a stock engine. Then you can set the carb to stock and be done with it. If you have no choice but to run aftermarket, start with the stock jetting and go from there. Might have to lower the pop off a bit from there or fatten up the pilot.
WaveDemon
Not Dead - Notable Member
Hell, Florida
fuel should never pour out of the carb. sounds like you have a bad n/s.
have you done a pop-off check?
I haven't done any testing with it yet, I just tried starting it late last night after I got the carb rebuilt. I only have the F/A, it came with the ski. Would I be better off with the 1.5 N/S that was in it?
WaveDemon
Hell, Florida
you need a pop off tester and test your pop off. also look over the carb tuning database thread to look for a good starting point.
from memory, where you're starting is pretty close but I think your N/S is leaking (test pop off to find out).
you'll see most 61x jetings are usually around 115-120 low and 140-150 high with a pop off in the 12-18 range.
dfw
The arm should be flat when installed. If it is sticking up it can hold the N/S open all the time. A 2.3 will a be a little rich with a 115g spring.
