Freestyle where to have cylinders honed and get pistons
I ended up getting a raider with a couple complete motors with eboxs that need repair. Also has trim so im psyched for that mod on my sn. Anyways where is a good place to have the cylinders honed. And get pistons. A few shops around here won't touch them. Thanks a ton in advance. Also curious what price range im looking at? Do you recommend the hone over cylinder trade to sbt. I would also consider having them ported/bored depending on price. Thanks again!
They are 61x cylinders and a 62t yamaha bottom and a 61 yamaha bottom. The 62t bottom is apart and one rod looks like it got hot because there is discoloration. Should it not be ran? I could get pics but will probably be a few weeks. And once again thanks!!
58vwragtop
Braap Certified
Blue Springs, MO
I would just order pistons online, but make sure you get at least .50 mil over the current bore size. Then take it to a local machine shop with the pistons and have them bored, honed, and chamfer the ports. You can ask the Power sports dealers who they use for machine work or just send it out to one of the jetski shops like Xscream, Jetworks, Blowsion, #zero, ect.....
