FX-1 Where do I tap the stock pump for dual cooling?
Fx1
Michigan
There doesn't seem to be enough meat on the vein part of the pump to drill and tap threads for a 90 degree fitting. Just wondering if anyone else has tapped the stock pump and where?
kcmasterpiece
Sweet Baby Ray's Sucks
Daytona Beach
my guess is you wont find many who have tapped a stock pump. mainly because whatever you have going on in the engine bay that needs dual cooling, the pump is too small for it anyway (if that makes sense). adding a b pipe alones get pretty close to the limits of the stock fx pump. you will probably need to do a pump swap and then run dual cooling if you need to.
