my guess is you wont find many who have tapped a stock pump. mainly because whatever you have going on in the engine bay that needs dual cooling, the pump is too small for it anyway (if that makes sense). adding a b pipe alones get pretty close to the limits of the stock fx pump. you will probably need to do a pump swap and then run dual cooling if you need to.
