Where can I get a rubber gasket
The problem is where I put the thru hull.
You can barely see where I drilled the hole. the white dot in front of the left rail.
http://s27.photobucket.com/albums/c155/brian_roy_6/SJ Build/?action=view&current=IMG_0031.jpg
Well I measured once an drilled once. The flange on the thru hull doesnt sit flush. maby 1/16 high on one side. So If I put a nice gasket under it. It would be fixed.
Is that the JD Short or Long rideplate? I'm running the short and I am very happy with it when it's not tearing up my shin. :banghead: :biggrin:
B-Roy
Makin' a Comeback!
MICHIGAN
I Need something to go on the outside of th hull under the flange of the thru hull.
Ill head to my grandpas tomorrow Im sure he has the material, and the tools to make it purrrrfect.:purr:
B-Roy
Makin' a Comeback!
MICHIGAN
made them today.
Note ID make it one size smaller ie 15/16"
Note 2, Gasket cutters do not like cutting 1/8" rubber well.
But they came out good after a damn hour.
