whats it worth?
i recently inherited an original owner 1989 x2, it was my uncles since brand new. he rode it a few times a year including a couple local races back then. it hadnt touched water since 1998 when he broke his hip in a collision racing it. stored in his shop its entire life. when i got it, i inspected the carb and fuel pump, rebuilt them even though i didnt need to but since i had pre purchased the carb and fuel pump kits from jetmaniac, i installed them. fresh plugs and fuel and it fired right up. i rode it for a 2 hour ride on our annual thanksgiving ride with zero issues.
now with that said. i am going to yamaha swap it.. as im more of a yamaha guy and i have a couple nice motors ready on the shelf.
the complete 650 drive train including electronics and exhaust will be removed. the motor has a mariner head and reads an equal 190psi in each hole. it has a aftermaket chamber cone with a water bung and is running the stock exhaust dry mod. other than that it is stock. what is that worth to someone as a package deal? thank you for your time!
way2manyhobbies2keep
https://www.ebay.com/usr/way2manyhobbies2keep?_trk
Sandy Eggo
in Socal, id say $500 engine, $150 pipe, $80 silver ex manifold, $200 electronics
Might want to keep the pipe unless you are going factory pipe. you could use it on the swap with an adapter.
