Super Jet What would cause this piston wash?
A stuck open needle causes an overly rich condition at low RPM's. If it's bad enough, the motor isn't able to get past it into the higher RPM's.
A worn needle is almost the same, but not as bad.
D-Roc
I forgot!
So true! yeah i think that that would be noticable with the way it runs, but not everyone can pickup on their motor's behavior. I guess that if the needle is leaking it would not effect it at high rpms but make it rich down low like the pop off was not set proper. I think it is safe to rule that out because he said it ran good and the piston wash is kinda sudden observation. would a low richness even change the piston wash? i figured piston wash is from mid-higher rpms
