Hmmm, I see that. I'm not wild about their prices however and hate going downtown unless its absolutly necessary, probably stay with US Composites. Last time I went down there, I got another ticket, they have a number of intersections that are known ticket traps.:shooter3:Call Fiberlay and ask what they got and what they recommend. Those guys know Skis somewhat, and they should be able to make a good recommendation.
They're in your neck of the woods, too.
I prefer to reinforce w/ fiberglas biax and use the thinner CF for decorative reasons.
How about single 17oz Biax with black Pigment? Used that on the X2 last winter. I just want enough strength , but don't ever see myself dropping from 20-30 feet like Ross or Caker.
I'd probably be ahead of the game wrapping my whole body in Carbon fiber as it seems to get broke more than my ski's.:crying:thats exactly what I used to reinforce my fx
1 layer 17oz, 1 layer C/K for decoration.............it really made it feel MUCH stronger than stock....
and Im with you....My ski will never take a beating like ross/slutty or cakers.....
when i did mine last winter i did this:
-roughed the sides with 60 grit and cleaned
-filled bond line with epoxy mixed with 410 filler
-1 layer 8.5 oz biaxiale - 4" wide strip over the bond line
-1 layer 8.5 oz biaxiale - 8" wide strip over that
-1 layer 12.5 oz texalium - full side - bottom to hood lip
all three layers extend from nose to bulkhead and i did all three at the same time along with the bond line filler as to get the best mechanical bond between the 3 layers and the hull.
squeegied out as much extra epoxy as i could as well.
dont forget to fill the voids under the pole bracket area with foam and glass that up too....
did that... filled with foam, then did two layers of 8.5 under that area. and since i hit bottom so many times i reinforced the nose... one layer of 8.5 oz inside the entire nose area, then one layer of 26oz - i had to pretty much reconstruct it. then the outside with a Taylor Curtis carbon kevlar nose piece.
