SX/SXi/SXi Pro What to do with the oil injection lines?
I am planning on running premix this season and doing away with the oil injector on my 95 750SXi. Now, what should I do with the injector lines that run into the carbs... plug and leave the lines, remove the lines and plug the holes??? I had a seadoo 580 years ago that I just plugged the lines on and it did fine but I would rather do away with them all together. Any thoughts?
SW UT
Remove the lines, then cap the ends where they hooked up to. Or you can plug them, though would just be harder to undo if you ever wanted to.
baxt3r
BBQ
Charlotte, NC
Seems like a good kit will come with everything you need. I remember the blockoff kit for my old GP1200 came with plate, gasket, and caps. But, it's not a Kawi.
