What size/pitch bolt???
2lick
Brap!!!
Limerick, PA
Give me the Thread Size-Pitch-Thread length (mm)-Total bolt length(mm):
example: head bolts M8-1.25-25mm-50mm
I need to know for:
Bolts that attach bedplates to motor mounts
Cylinders to cases
reed cages to manifold
reeds to reed cages
stator to cases
flywheel to crank nut
thanks!
-nick
michael950
for me to POOP on!
Houston, TX
I need to know for:
Cylinders to cases
reeds to reed cages
stator to cases
thanks!
-nick
Patience little grass hopper, I can get the measurements when I am able to continue work on my engine.
stator to cases - same size screw used as the lug screws in the e-box.
flywheel to crank nut - you should use an OEM bolt not a replacement
everything else I can get later.
