FX-1 What part would you throw at it first?
samsmith87
Chicago
I took a clean 61x out of a VXR pro never ran it just checked compression 150 and 148. I put it in a FX1 hull added an ADA head with 35cc dome, Factory pipe, and WetJet intake with a BlackJack 46 SBN.
I emailed Art for recommended jettings and put in what he said:
2.5 needle and Seat
115 Gram Spring
160 Main
130 Pilot
Went to start it and it wouldn't rev out.
So i took a 44 sbn that was jetted to what factory pipe says and got the same thing.
Here is a video of what it is doing.
What do peopel think CDI? Stator?
Quinc
Buy a Superjet
California
Check your grounds and try it on the water. My blaster used to bounce of the rev limiter like that but ran great on the water.
samsmith87
Chicago
So i did drop it in the water thinking the same thing. It had the same symptoms and just putted around.
Also the Temp sensor is deleted with the OCD kit.
Quinc
Buy a Superjet
California
Make sure your flywheel key is still in place and check your stator. Probably wouldn't hurt to throw a new cdi at it too.
samsmith87
Chicago
So i replaced the CDI with the one out of the WetJet and it acted the same.
So I pulled the motor opened the flywheel cover and oil came out. Looks like there is oil in that area.
I am guessing the stator is shot and causing it to run funny.
DAG
Charlotte, NC
Sounds like you need to leak test your crank seals if you are getting oil in the flywheel area. JETTLab Products sells leak test kits
PS: You can ohm a stator and verify. Get a manual and start checking.
Try a CDI without a rev limiter,( MSD), we all had similar symptoms when goin to B pipe,especially if you have stock pump.
