- Sicily, IT
Hey guys just picked up a pair of 48mm annular discharge carbs and not sure who made them. Im thinking blackjack??
They're soaking in it now, all holes are clear. These bad boys were pumping and running before i got them.I would fully strip those and soak them in chem dip for an hour or so to get all the crust out. Also spray some carb cleaner or pressure some gas and squirt it into the fuel inlet to make sure it flows out of the 12 holes.
Huh wow I knew they were good but not that good. Thanks for the advice.Sadly, yes.
46 SBNs are underrated. Jetted correctly, bone stock 46s can perform 90~95% as well as the best carbs on the market and outperform everything else. For the money they can't be beat. You can also throw two factory square nose air boxes on top to help keep out water.
Get a good manifold and a decent set of reeds to go with them. Heck, Carbontech low-tension or OEM Kawasaki SXR petals on 62T cages work great and last forever. You'll have an inexpensive, reliable, easy-to-maintain intake setup that keeps you riding.
