CHRISRACERX
Get Wet
- Galloway, nj
Hey there guys. I have a 2008 Superjet with almost everything wrong. Only thing that doesn't need attention is fixing cracks on the hull. Note I said cracks. It still needs a fresh paint job. Past owner left it outside uncovered it's whole life. I got it cheap because it also had a seized engine because of water intrusion. It's all apart and I plan on doing a full build thread on it. I have its original engine and I have a complete 760 (electronics and all). Both need rebuilding totally. 760 needs the bottom case welded after it threw a rod in my WB2. It's cracked but repairable. I've never seen anyone use stock 700 exhaust on a 760. I don't want to use an aftermarket pipe yet. Will they be compatible? I know it will bolt up, but how will it run being port size and timings are probably different.
Thanks for any info. Will start putting up start pics up soon
