What engine is this????
yamanube
This Is The Way
Staff member
Mandalor
Like Franny said, its not a bad motor but the motor you have now will likely be more desirable for a superjet.
My current motor is ported but need new starter bendix 2 x carb rebuilds and stator. So was thinking buying this new motor and selling old one in parts,
Could the 62t barrels be ported similar to 61x??? Are the pistons the same??
yamanube
This Is The Way
Staff member
Mandalor
You would be better off buying a new bendix, stator and rebuilding your carbs. You could buy this motor, steal the bendix, carbs and stator and sell the rest off but I can't imagine it is a cost effective option. Yes 62t and 61x cylinders can use the same pistons, assuming the bore is the same.
I think you are making this way more complex than it needs to be, you are looking at under $300 to get your current setup fixed and you would have a ported setup. Why would you want to go backwards and start with something that is not even close to what you already have?
