chriselmore_1
high on resin
- san jose ca
i was getting ready to swap cylinders and was comparing the to. it looks like my old cylinder had extensive porting to the transfers and boost ports. lik boost port was made bigger and is lowered. the transfers apear to be wider. its a 0061x cylinder. the sleave to casting is flawless. exhaust ports were about 52mm wide measured with the diameter not across. the sleaves were cut and countersunk below the bottom of the cylinder castings too. i will post some measurements when i get home. just curious about this setup with for a limited motor for freestyle/freeride
