- HOLLAND MA.
Features: Durable Poly Casing, Horizontal or Vertical Mounting
Length: 5.8
Width: 3.4
Height: 4.1
Weight: 6.3 lbs
Performance:
Voltage: 12
Pulse Cranking Amps: 527
Cranking Amps @ 32 F: 283
Cold Cranking Amps @ 0 F: 210
Reserve Capacity: 20 Minutes
Capacity (C/20 Rate): 11 amp hour
Internal Resistance (Ohms): 15.8 milliohms (0.0158 ohms)
Short Circuit Current: 760
Recommended Uses:
Extreme Lightweight. Vehicles Full Race Cars
Extreme Audio Builds very small space and a need for multiple batteries.
Custom Cars / Choppers. No Acid to Spill - protect and enhance your vehicle!
Not Recommended For:
Cold Climates
Long Term Storage
Large Displacement Motors with High Compression
I know it says no high comp...but i think its refering to a 4 cyl with high comp. My stroked lam will be 200psi. My Oddesy weighs 13.1 lbs,so this is smaller and more than half the weight.
Length: 5.8
Width: 3.4
Height: 4.1
Weight: 6.3 lbs
Performance:
Voltage: 12
Recommended Uses:
Cold Climates
Long Term Storage
