Quinc
Buy a Superjet
- California
As some of you know the jet ski Gods hate me and have cursed me with running into every possible issue. The latest issue being a small hairline crack in the cylinder liner that I found after taking the cylinder off to remove broken bolts... So before I replace it with a new one and have it happen again I would like to try and figure out/fix what caused it in the first place.
Ported 61x 701, 62T Piston rods, 6m6 crank, Pro-Tec head with 155psi compression. Coffman Rocket exhaust and SBN 46mm Carb. Run 91 Octane.
