- minnesnowda
I have an rn with a 62t/62 bored to a 760, mild cylinder and case porting, 175psi head, prok fa's, stock 38s, carbon tech reeds, b pipe with blaster chamber (4mil restrictor in Stinger sprayer, top screw 1/4 turn out, single cooling)
So my problem is and has been that it loads up in lower throttle/rpm, runs ok up top. Ive gone from 75pilots all the way down to 67.5s. Which seemed to help but didn't fix it. I then got a lean bog at idle to wot. So I dropped my pop off from 25psi to 21psi. Again seemed to help but didn't fix that totally either. Ive gone all over the place with the screws and had little success, and made the idle much worse lol, which is what I expected I guess lol. I'm runing 137.5 mains BTW.
So what am I missing here? Carbs were rebuilt end of last year, comp and plugs look good? Reeds? Plug wires? Any help would really be apreciated!
