seatsR4toilets
Just spell my name right
- In Your Head
Knowing what I know, I'd pay up to $250 for a complete set up.
But, that's me, and I'm an idiot.
can I modify a standard 46mm carb to work?
so the only thing different over stock are the stuffers?
you can buy used 62t cases for 300 or less and buy one more 44 to add to your stocker for dirt cheap,and smoke the power of any mani on a 61x case.these things are over priced
i got a 61x case 701 that will give any 62t cased 701 a run for its money. ported or not. + you have to look at most plp cant do a case swap.but they can change an intake.
What have you done to your case? Im really interested in hearing your setupyou can buy used 62t cases for 300 or less and buy one more 44 to add to your stocker for dirt cheap,and smoke the power of any mani on a 61x case.these things are over priced
Wet Jet mani swap is a 20 minute job if you take your time.
Can you do a case swap and porting in 20 minutes?
Like I said, for the money it's a cheap, easy, low-buck mod for the 61x guys.
