Wet jet pipe info
JetManiac
Stoked
Vendor Account
orlando
I have a Wet jet pipe that came bolted on a 62t motor in a couch that I bought. Motor was seized so I didn't get to see how this pipe performs.
Does anyone have any experience with this pipe?
Also what do these sell for?
Any help appreciated.
Tuscaloosa, AL
the pipe was made by Westcoast if I am not mistaken. It is not an Aftermarket Pipe. Westcoast use to make the OEM pipes for Seadoo as well, they may still do so, not sure.
Cannot tell you how well it would work, I can tell you that it will only work on a couch with the waterbox to the rear of the motor without doing some crazy rerouting of exhaust lines.
QuickMick
API 1104 AWS CWI
I had a friend that tried to drop one in his blaster. it would hit the inside of the hull. wouldnt fit without grinding the hull. He tried everything to make it work.
Yohns Kustom Fabrikation
Pushing The Limits
Bushnell, Fl
I have also seen this. I have 2 of these pipes on the shelf. The pipes for the Wet Jets all seem to be the same externally but the Kraze model skis have a lot larger inside diameters than the other models. The Kraze pipe is also alot lighter than the others because of the thinner castings.
