well got this superjet hull..
2001 with no motor or pump or any of that good stuff. and also got a b1 sittin here that no one really rides. got a bunch of motor work with a b pipe and mod chamber...what parts are interchangeable into my sj until i get my sj motor built? with a sj motor plate and sj motor mounts could i put in that motor? what parts exactly can be put in a sj from a b1?
FL
Bed plates are the same. Motor mounts are different. You have to dent the mod chamber quite a bit to make it fit. Head pipe is the same, so I would just try to pick up a SJ limited chamber. Pumps are interchangeable. Driveshafts are not, I don't think midshafts are either. You wouldn't really need too much to make the swap.
