- Melbourne, FL
The alignment pins on my wear ring and stator section don't line up. They are around the same bolt hole, but on opposite sides of the bolt hole. Can I grind the pins off? I pieced together the pump so I don't know the years of everything but I believe the sttor section is from an early year squarenose.
Just realized that I posted this in the general section and it should probably be in the Driveline section. Sorry mods.
