waterfreak
I had a vision!
- s florida
We now have some ovp steering systems in stock . They all use fat bars . $200 + shipping
uses thrust bearingsWhat is the bushing system?
I’ll take one ASAP. Lmk how to buyin stock RTS
yes, it attaches with 6m bolts with lock nuts underneathdoes the bottom have the 4 small bolts to attach the the pole? or how does it attach to the pole I'm looking to replace the krash industries one.
Ill take oneyes, it attaches with 6m bolts with lock nuts underneath
As far as I know, this is basically the same as rrp x-lite steering. On my rrp x lite, i was having trouble with it coming loose when new too. On the base where the center bolt threads in, there is a stainless “insert” that has left hand threads on the outside. This was coming loose causing the issue for me. After I cleaned it up, put red loctite on the left hand thread and let it cure before assembly, no more issues.For anyone wondering about this steering i got it and it’s not as good as the thrust ones. I figured I’d try it because thrust was out of stock but now I regret not waiting. Would not buy again it comes loose just like the super poopy krash one that I replaced.
There you go! You got to set it up right the first time them your all set !As far as I know, this is basically the same as rrp x-lite steering. On my rrp x lite, i was having trouble with it coming loose when new too. On the base where the center bolt threads in, there is a stainless “insert” that has left hand threads on the outside. This was coming loose causing the issue for me. After I cleaned it up, put red loctite on the left hand thread and let it cure before assembly, no more issues.
