Honestly I had a GP800 that I got with a stuck engine, I also had a good XL1200 engine laying around, I put the two together , same impeller , it pulled almost exactly the same and it didn't hit the rev limiter so I know it wasn't running out of impeller , this is how I know everything hooks up and works from one ski to another .Thanks for the response. My doubts actually came from the similar power output, though it's not just about power alone. The GP1200, lacking Nikasil plating, is a bit easier to port, and I feel like there’s a lot more potential to unlock from that engine. But when I consider that my current engine can successfully drive a 15/19 pitch impeller, moving up to a 16/23 pitch would, of course, be a big leap, but I’m not sure if it’s worth the investment. When I rode the WaveRaider 1100, it seemed to have a stronger kick than the WB800, though that could also be due to the shape of the hull. It would be great if someone could share their experiences with the WB800, especially comparing the PV800 engine to the NPV1200.
1200 will make it plow more water with the extra weight. Put a set of 48 carbs on, really wakes ski up. Make a new steeper baffle cone for the exhaust, 20-24 degrees, pipe rpm will match porting rpm better. Install 148mm Solas pump for better hookup. On my race ski I used to have alu strips bolted to the underside of the plate, helped lift ski for less drag and acted as mini sponsons when turning.
Yes, same Solas Mag as for a SJThank you so much for your reply!
Did you mean a Solas Mag pump like the one used in the Superjet, just mounted on a WB800 driveshaft? What impeller and pitch were you running? Do you remember the distance between the impeller edge and the pump stator?
Also, did you modify the stock head, or leave the cylinders unported and compression unchanged?
And one more thing - do you happen to have a drawing or photos of the new 20–24 degree steeper baffle cone for the exhaust?
