loictahiti
- Tahiti, french polynesia
Crazy man , crazy built , love it
Subscribed for sure
Subscribed for sure
It was cool as hell to see that thing in person, is that monster sport gp legal?
So what does that Spark motor make power wise in stock form?
What kind of horsepower are you projecting to make with this monster?
A naturally aspirated spark engine makes 90hp factory - 110hp reflashed
A turbo canam maverick has the same exact engine but uses 10.5:1 pistons instead of 11:1 pistons that are in the spark motor and the maverick makes 172hp at flywheel stock - 12ish psi.
A turbo spark engine is 250hp capable at 20psi. I have no clue what I would be comfortable running power wise until I test... Will probably aim to end up in the 150-180 range for initial testing and go from there.
I see you have cooling everywhere. What's the plan to keep all this cool? How is that setup on the rear exhaust with all that cooling work with the manifold? Can you snap some pics of all that hooked up before you put the lid on it?
What a masterpiece!
20160206_194605 by Ricky Hinch, on FlickrHorsepower is not relevant to PSI. Saying "250hp @ 20psi" is a meaningless silly statement. What at turbo can flow at X psi is more significant. Turbo A can make 250hp peak at 20psi, turbo B can make 250hp at 12 psi.
So why go into a manifold and 3 injectors into the straight pipe as opposed to one injector and no manifold? Is it because one injector won't give you the flow rate through the rest of the system and is too restrictive?
Also why arrange the injectors in this fashion. Essentially three in the same spot as opposed to one after the other maybe a few inches apart?
The reason I ask is because when I put in my triple I may inject water for to make it quieter. So if I pulled a second cooling line off the pump and injected it in the pipe what would be the best setup to be the quietest? Three spread in the same spot or one after the other over a few inches?
20180424_184102 by Ricky Hinch, on Flickr
20180424_184508 by Ricky Hinch, on Flickr
20180424_184516 by Ricky Hinch, on Flickr
20180424_184533 by Ricky Hinch, on Flickr
20180424_184658 by Ricky Hinch, on Flickr
20180424_190317 by Ricky Hinch, on Flickr
20180424_190507 by Ricky Hinch, on Flickr
20180424_191203 by Ricky Hinch, on Flickr
1 by Ricky Hinch, on Flickr
4 by Ricky Hinch, on Flickr
4a by Ricky Hinch, on Flickr
5 by Ricky Hinch, on FlickrHow does the press fit PTO work, seams like it would slip?
