Super Jet WB1 to sqn superjet advice swap parts
ventura
Ok here is the issue I want to transfer my blaster guts into the superjet. It has a nice 701 and a mod pipe. I read post about the factory mod pipe not fitting and having to melt gas tanks to make it fit. What would be my best way to go in this case. Also do I need to switch Eboxes thanks for looking
JetManiac
Stoked
Vendor Account
orlando
You will need SJ length driveshaft in the pump.
Midshaft will fit in a 94-95SN, but you will need smaller housing for 90-93SN.
Intake grate is the same, but rideplate different.
Motor mounts and steering cables are different. Throttle cable is the same.
The engine, ebox, and electrics are the same but the S/S/S has longer ebox pigtail and shorter on the switch itself. If you transfer both over, you will be good. Battery cable to battery is too short and will need to be swapped.
waterbox, steering, tank, hoses are different
