Blaster WB1 issues
New to the forum and to owning a waveblaster, I am experiencing some weak spark or another issue as soon as I get on plane. I have been through the carb and rebuilt to factory spec and eliminated that as a possibility. As soon as i go to get on plane it feels like i lose a cylinder and am barley able to hold it up. Good cold and warm compression in each cylinder and am showing fuel delivery in both cylinders as well. I suspect the ignition coil and wanted to check and see if this is a common problem. Any and all help and advice is much appreciated.
fl
i had the same problem it felt like it would run on 1 cyl and you have to play with the throttle to get it back to normal. i took both spark plug boots off replaced them with new ones and i cut a little of the plug wire about 3/8 off. it solved my problem.
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Try new plugs first if you haven't already, but yeah, cut back your plug wires till you see good conductors and then screw the caps back on. Another possibility is the overheat sensor putting it in limp mode.
Blasterobb17
need water now.
nj
ya i had the same problem 2 years ago.. it was the spark plug caps being rotted out. got new ones and it is fine now
