- baltimore
New to the forum and to owning a waveblaster, I am experiencing some weak spark or another issue as soon as I get on plane. I have been through the carb and rebuilt to factory spec and eliminated that as a possibility. As soon as i go to get on plane it feels like i lose a cylinder and am barley able to hold it up. Good cold and warm compression in each cylinder and am showing fuel delivery in both cylinders as well. I suspect the ignition coil and wanted to check and see if this is a common problem. Any and all help and advice is much appreciated.
