Blaster Wave Raider water box flow direction
ItsRixter
SoCal Wav Jumping shiznit
Sunny Diego
I am going to install a wave raider 1100 waterbox in the rear of a B1.
I have a unique situation in that the Riva rear exhaust is already installed on the left side.
I can make it work if the flip the water box around but will the water box work correctly regardless how the exhaust flows?
Another way to ask is: Are the intake and exhaust on the Wave Raider water box specific? Or is this just a glorified tube and it doesnt matter which end is IN and which is OUT?
Thanks for your input and help.
orlando
it wont matter at all. the baffle inside is not directional and the inlet and outlet pipes arent different enough to matter. ive cut many of these boxes open to play with the baffling and re weld in different shapes etc.
Maine
I know this is an older thread but I thought I'd post how I had the raider wb openings rewelded so that I could run the stock location with the 1100.
