joe b
depth tester
- northfield, nj
I've got my whole tray area removed for some reinforcing, refoaming, removing footholds. While I'm in there I'd like to seal any possible leaks and I'm curious what I should use in these areas:
driveshaft is leaking/ Use 5200, epoxy or something else?
cooling, steering, trim lines/ 5200?
Should I do anything with the green stuff the factory uses on the hardware from the rideplate & intake?
Thanks
Thanks
