I have a SXR and I landed poorly on a barrel roll, causing it to land upside down and remain running. It sucked in a good amount of water and some got into my cylinders. I flipped my ski upside down at home and started it repeatedly (while spraying it with WD 40) to get the water out, and a couple ounces of water came out. Do I need to take my cylinders off, so I can peek into my crank case for more moisture or water? I need to to know if it's necessary ASAP, because I'm worried about my engine!
Thanks!!
Ross
Thanks!!
Ross
