BruceSki
Formerly Motoman25
- Long Island
You guys wrapping skis and handlepoles, what is the trick?
Does the type of squeegee used matter?
heat gun or blow dryer?
should you wet the vinyl with some water slightly tainted with soap?
Just tried doing a handlepole with 3m scotchprint and the first try was terrible. second try was a bit better but only really looked good on the front, once we made the turn to the backside of the pole it sucked.
Just trying to figure out what the trick is to making it look like a professional job. Trying to install this stuff makes turfing look like a cakewalk!!!
