VF2 reeds " what does this test indicate?"
Yesterday I decided to install the angled reeds spacer, and then I decided to clean my VF2 reeds and I noticed something!
If you hold the reed like the port is up, there are 6 pockets like 2/2/2. When I spell water inside these pockets “slowly” the center pockets will hold the water but the sides pockets will leak the water in seconds but each side will take deferent time. Is this normal? Or side pockets should hold the water?
It indicates that the reed tension is weaker on the outside petals.
How old are the reeds?
