Unhooked gas tank strap, cant get it strapped back in
On my squarenose I needed some hand room so I unhooked the gastank strap (the side you can easily see.) when i went to hook it back up, it had come loose from the end I can't see!!! I have no manual, where does the end you cant see hook? and can I get it hooked back in without removing? does anyone have a diagram? help plz.....
hermanns
poor
gainesville, fl
I am referring to how it is on my RN, but it shouldn't really be any different. The gas tank filler I am referring to the tube that goes from the gas cap to the tank, it is hoseclamped on. Take that off then you can slide the tank forward w/o removing the battery, but not very far, but you don't need to, only enough to see where to reach and stick the hook back on.
ToddW
Web GuY
Folsom Lake - CA
To slide the tank forward on my SN you have to remove the battery box. To remove the gas tank on my SN you can do so w/out removing the battery box it's just super tight.
-Todd :Banane19:
