SN760
For Those About To Rock
- Dallas-Fort Worth area
Have a few questions------
First here is what I'm running for a motor. 62T cases and cyl. Cyl resleeved and bored to 84.5 mm. Cyl - heavy porting. ADA head with 28cc domes (215 psi comp.). Boysen manifold & reeds. 46 mm Team Scream carbs with X-Metal risers. MSD Enhanser and lightened flywheel. Weisco pistons.
Was running a B pipe with mod chamber, switched to a Type 4 Dry pipe no water injection - BIG Improvment - also at that time was running 33 cc domes (180 psi comp.). with 84 mm bore. No problems with the dry pipe couplers etc. etc. really liked the power increase it gave me.
Lost part of the ring lands of one piston 2 week ago, no signs of detonation, sticking, lean cond. etc. Motor had a LOT of hrs on it, also at that time was running stock yamaha 760 cast pistons.
Back to now - new crank, new Pistons (weisco) fresh bore. new domes (28cc) willing to run race gas. Finally the question --- Do I go back to the B-Pipe (kinda the way I'm leaning with the big jump in compression) or can I run the dry pipe and get the motor to live?
Talked with Factory Pipe - they said the dry pipe type 4 was made for a motor with limited porting - and the big one - low compression, in other words Don't Run It with this motor setup.
Any thoughts on this???
Thanks
Mark
Thanks
Mark
